Pete F
Titanium
- Jul 30, 2008
- Sydney, Australia
I was just reading an article in a British magazine regarding the manual generation of an involute gear profile using a V profile rack tool, by firstly cutting just the V, then rotating the gear blank a specific amount and correspondingly moving the cutter in/out a specific amount, indexing around the whole gear and repeating. The author says that 4 passes on each tooth side provide a step free tooth profile. I can see this would be a very handy method for one-off gears, where it's not worth buying a full set of cutters, and on gears with a small number of teeth it probably isn't as time consuming as it sounds. I normally just set up the power feed and stops to cut each tooth, so it's semi-automated anyway.
I'm curious as to whether anyone here has tried this method, and if so how to determine the relative angular rotation and in/out feed required for each pass? I can see it would also be possible to generate undercut teeth using this process, and would this allow a lower tooth count gear as compared to using horizontal involute profile cutters?
