I need to make a small lot of thin parts out of A2 tool steel (1/16" thick x 3/4" wide x 4" long)and have them heat treated to full hard. The parts have minimal machining on them (cut to length, 4 small countersunk holes, and a small section machined out on one end to create a fork like feature).
I'd like to minimize any warping of the parts. Can thin A2 parts be clamped together in a stack and heat treated in a vacuum furnace or will they "sinter" together (not sure what the actual term is)? I'd call the heat treater, but they are closed on Fridays.
Does anyone here have experience with clamping parts for heat treating or have any pointers? If I stack the parts, should the countersunk sides be stacked opposite each other? Recommended size and material for the clamping plates?
Any help is appreciated.
