matt954cbr
- Dec 7, 2015
I recently acquired a Futaba Pulscale DRO - model CJ2004 (2 axis) digital readout which I have installed on my 9 x 42 bridgeport mill. The problem Im having is that the resolution and accuracy settings seem to be off. .200" of table movement in reads 4.00" on readout... There have been previous threads on this topic (most recently about 6 years ago) in which people have found old manuals and transferred them via e mail in PDF form. I have scoured the internet searching for any type of setup manual... The closest I could get was an operators "card" but this had no information on how to access the setup menu of the unit. From what I was able to find (which was very little) the setup menu is accessed via a sequence of button presses and then the setup parameters can be adjusted. Two double a batteries power the internal memory and because this unit was out of service for years... the batteries died causing it to lose any save parameters. I also found that there are other models with dip switches on the internal circuit boards but this unit has none. If anyone has a copy of a manual or experience with using one of these DROs your assistance and/or advice would be greatly appreciated!
