gibsonj
- Jan 16, 2014
- Albany, NY
Hey all,
we work with Invar 36 for some baseplates (12" x 17" x .5"). We've had them done outside and are just starting to do them in house. I need some help, specifically with tapping the plate. The first one I did went fine and I could get about 18-20 holes out of a hand tap before it started to feel dull and I'd switch to be safe. After about 4 months since the first plate, I'm doing plates 2 and 3 and having a real hard time with tapping 1/4"-20 holes. I'm using the same Guhring blue ring taps that I used the first time (and for other invar projects), I'm using the same size drill hole (a .208" from a Guhring drill), and the material is from the same batch as the first plate. When I started tapping these holes, they were WAY more difficult than the first plate. I'd make it about 1/2 turn or less before chips would build and I'd have to back out and go again. That's fine, but I was making it much further with the last plate. After the first one I switched to another tap (of the same type) to see if it was possible that one was dull and I had the same issues. After 3 holes with that one I broke the tap off in the part.
I have around 90 holes to do, and the way it was going in the first plate I did a few months back it would have taken some time but would have been ok. This, however, is torture. I'm using tap wax and doing everything I can to make sure the tap is nice and straight.
Does anyone have any suggestions to help me get through this?
Thanks a ton in advance
