Help identifying tool steel please
Results 1 to 14 of 14
    May 2011
    Northern Virginia, USA
    196
    39
    24
    Default Help identifying tool steel please
    Only markings I have are E93909 and RH 4-2
    Any help with what this might be would be greatly appreciated.
    1/2 and 5/8 hex bars. Originally bought to make stone chisels. Need to identify so I can properly harden.
    Jim.
    May 2011
    196
    39
    24
    Wow. No ideas?
    How much trouble will I be in if I oil quench and then draw back? Sound reasonable ?
    Jim.
    Aug 2004
    Richmond,VA,USA
    1,962
    146
    664
    That is exactly what I would do. First you have to assume it is oil hardening (something of a guess here). Heat it up until a magnet will not stick to it (bright cherry) and plunge it vertically in a fairly large container of oil with a lid just in case the oil ignites. Check with a file to see if it is hard as woodpecker lips. Polish one side with a cratex wheel, course steel wool, or whatever you have that will do the job to remove the fried on oil. The oil I use is generally not very clean so this may take a little effort. Heat the hammer end very slowly. Don't put the flame right on the metal or you will miss the bus when the colors start to run. Hold the flame maybe six inches away and be patient. You don't want the color bands to be too far apart however because the business end may get hot enough to temper before the hammer end has softened. Adjust your heat so the bands are about one to two inches from straw to blue. When the cutting edge is a dark straw then quench again quickly and swirl it around. Now if it is oil hardening and you did everything right it should make a fine chisel. If not then try water or brine.
  4. Likes JWaldo liked this post
    Oct 2005
    9,557
    16662
    4876
    Box of donuts, local scrapyard, XRF gun.
    Then you will know exactly what you have.
  6. Likes JRIowa, Porschefix, yardbird, JWaldo, Modelman and 2 others liked this post
  7. #5
    Aug 2004
    Richmond,VA,USA
    1,962
    146
    664
    I like your idea Digger but mine is more fun.
  8. #6
    Oct 2005
    9,557
    16662
    4876
    Quote Originally Posted by crossthread View Post
    Too "Harry Homeshop" for me....
  9. #7
    Aug 2004
    Richmond,VA,USA
    1,962
    146
    664
    You got to take time to smell the rosebud catching your pants on fire.
  10. #8
    Oct 2005
    9,557
    16662
    4876
    Please take this over to Homeshopmachinist.com
  11. Likes JRIowa, litlerob1, Leg17, Modelman, SIP6A liked this post
  12. #9
    May 2004
    Vista, CA
    943
    228
    247
    What does it smell like?
  13. #10
    Aug 2004
    Richmond,VA,USA
    1,962
    146
    664
    My wife's cooking
  14. Likes TeachMePlease, JRIowa liked this post
  15. #11
    Jan 2009
    "Stuck in Lodi", Ca
    3,114
    1842
    1617
    And I was stupid enough to read this whole thread beyond #3 thinking I might learn something more... sigh
  16. #12
    May 2011
    196
    39
    24
    Results.
    Oil quench was the ticket. These guys eat through the stone (marble) and rarely need re-sharpening. Tip hardness turned out just right. I made 40 of these (a lot of work).
    Thanks for the Great Advice !
    Jim.
  17. #13
    Jul 2005
    Eastern PA
    879
    108
    567
    Guy needs a bit of guidance making 40 stone chisels and some of you guys act like he's somehow "unworthy" of your consideration. Kind of surprised someone didn't recommend he send the steel out for lab certs and then to a heat treat shop with documented RC range. Sheesh.
    Nice job JWaldo. They look good. Hope you turn a tidy profit...........bob
  18. Likes JWaldo liked this post
  19. #14
    Nov 2002
    St.Louis, Missouri, USA
    1,853
    104
    400
    Quote Originally Posted by bhigdog View Post
    Didn't you know the inmates run this asylum?
    Dan
  20. Likes JWaldo liked this post
