Results 1 to 5 of 5
    berol is offline Aluminum
    Jan 2006
    Florida
    70
    Default Help, Lathe cutting small dia S/S rod
    Using 303 S/S and trying to reduce the Dia. of a 3" long section of a 4" long rod. The rod is 0.150" dia and I want to reduce them to 0.135" (+ or - 0.001"). Am holding the rod in a collet and supported by a center on the other end. Of course it wants to bend when being cut. Do any of you have some suggestions on how to accomplish this, SFM, DOC. lub & support tricks, etc. Thanks
    jims's Avatar
    jims is offline Cast Iron
    Sep 2004
    Sonora , Calif
    404
    Centerless grinding will work. Or a box tool. I made a box tool to do a job like that.
    l
    jim
    steve-l is offline Cast Iron
    Mar 2012
    Geilenkirchen, Germany
    366
    This is precisely why follower rests were invented. They mount on the carriage. I don't know what lathe you have, but look for two threaded holes on the right side of the carrage, as that would be where they would mount. Follower rests are shaped like an offset "C" having 2 adjustable arms that bear on the work resisting tool pressure deflection. The arms come in two varieties one with ball bearings and the other plain. The plain style require grease lube.
    Dualkit is offline Titanium
    Apr 2005
    Beaverdam, Virginia
    3,646
    How many to you have? It might be worth it to take them to a centerless grinding shop. You could probably get a few dozen done for minimum charge of like $85.
    Dirtywiskers is online now Aluminum
    Jul 2012
    USA Kansas
    67
    In a collet with a center do a length 1 1/2" pull out re apply center repeat untill done maybe leave a little spot to file to size apply emery cloth no one will ever know but U
