Austin.clayton
- May 27, 2017
I'm going to be honest, I have no idea what I am doing, at least with the things I'm asking help on.
I'm designing a sword with mechanical parts. The blades need to sit on a linear bearing to slide in and out. As well I need to either make or buy hinges for other parts. Attached is two models from a sketchup file, one open and one closed. If you have sketchup you can just import them. Also, there are two pictures of the linear bearings if you just want to look at those.
View attachment sword closed.zipView attachment Sword opend.zip
In the model Green is the two linear bearings, red and yellow are two different types of hinges that I'd like to be able to buy, and blue is the hinges that I think the 4 inch hing at lowes will work just fine (since its not really a load bearing hing I don't have to worry). The CAD is just a rough idea at this point. I need more info on the linear bearing and hinges to really hammer down the details.
The trouble is with the linear bearings mostly, again I have no idea what I am doing, so if anyone can help me determine what type or how strong I need it would be helpful, or just point me to any sources I can use to figure this out. The hinges are more just if anyone knows what type I could buy or what would be the best way to make them.
I've done some woodworking before so designing and building are not completely foreign to me, I just have no clue about details like what type of linear bearing is needed strength wise.
Thanks a lot for any help, and if this is the wrong thread for this can you just point me in the right direction.
