MARVINGARDENS
- Dec 13, 2014
- Central Valley, CA
Hi.
I have a question about something that is probably a bad idea. There is probably an obvious answer why this shouldn’t be done the way this occurred to me. I am sketching out plans for air plumbing in my shop. I see many articles that say that when the drops are made from the main pipe at the ceiling, there should be a “J” at the bottom of each drop to catch any moisture that might make it into the air hose.
Has anyone run their main air lines low, just above the baseboard? It seems that then most moisture would stay down in the main line. I would have to make one rise and then a drop go over a pedestrian door. I plan on installing some sort of anti-moisture device when I put my compressor and plumbing in my garage.
The air system will be used for operating tools and a blast cabinet. I would like to be able to use the system to operate a paint gun occasionally as well. I am buying a Champion 19.1CFM, 5 HP, 80-Gallon, Stationary air compressor.
Am I overthinking again?
Thank you
Bob
Thank you
Bob
