Apologies for not knowing any of the right terminology; this is not my area of expertise by a long shot. Also, apologies if this is in the wrong place.
I have drilled a bunch of 1mm diameter holes in the face of a square aluminum tube. The material is listed as 6061-T6, and is 1/4" thick (the tube itself is 2.5" square and 8' long, if that is relevant).
Naturally, by virtue of drilling the holes, the material is now raised slightly around each hole. I need the surface to again be flat. I think I could deal with having to countersink each hole a bit, if that would be sufficiently easier than any other solution, though I'm not really finding appropriate bits in that size.
Are there any other solutions available that I could do myself with limited equipment? If not, I am not entirely certain what sort of shop to approach to ask them to perform this work, and exactly what would be the easiest thing to ask them to do. Am I looking to have the entire face cut? Can you let me know appropriate terminology and help me look in the right direction?
Thanks!
Thanks!
