xavier2089
- Nov 29, 2016
I made the amateur mistake of trying to save some money using a solid round of 6061 T6 aluminium of 250mm/ 10 inches OD which was longer than I needed rather than buying another piece of the correct length. Big mistake, lesson learnt.
I have machined one end of it to the dimensions required for a 250mm pulley I am making. My 3 jaw cannot hold the part on the OD (as it is not big enough) so I have tried holding the billet on the ID of the pulley part and parting off the remaining stock using a parting tool. The part has slipped twice whilst I was trying to part. I tried using paper shims between the stock and the chuck but it slipped again.
I am currently using about a 9 inch slitting saw blade on the mill to try and cut the stock off which seems a very poor option.
A few question come to mind:
Was I doing something wrong when parting?
I ran a very slow speed and did the chuck up fairly tighty (I didn't want to use a bar as this could damage the scroll if I'm not mistaken?). Feed was slow and I cut 2 grooves side by side to assist with chip removal, kerosene as cutting fluid. I never have trouble on small stock. Seemed more of a case of work-holding trouble than a parting problem? Would the 4 jaw improve my chances or clamping it on a face plate? Or is it too deep a part- I have bored the middle to 124mm (250-124)/2 = 63mm of material on both sides of the bore?
Aside from buying the correct length of stock in the first place, how do/ would most of you cut short lengths (too small to clamp in the horizontal band saw, which I do not have BTW) of large diameter pieces (say round, square etc.)?
I have seen a post about vice extensions for horizontal band saws but one would need a hefty size saw to cut something of this size.
Are large slitting saws say equivalent to a cold saw or is it a bad idea to use this as a cutoff tool?
Looking forward to people's thoughts,
Xavier
Xavier
