Mr g
- Feb 8, 2011
- Vancouver, Canada
Just to give you guys a little info about myself, the last two years I've been aquirring machinery to setup my own job shop.
I purchased this paticular colchester mascot 1600 at an auction knowing that it was missing the coolant tank. Now in the next few week I wanted to get this lathe up and running but seen something weird on the back of the head-stock.
I noticed it's missing a few more things as well, the plate that covers the drive motor is missing, as well a cover plate that I'm pretty sure would have the serial number and date attached to it.
I've found these two hoses coming off the back of the head stock that look out of place and in place at the ame time. One is capped off at the end its a clear about an 1" ID. The other is a black hose with high pressure fittings. Both are just hanging there and attached to the head stock just under the clutch shaft assembly.
So the question is, do these lathes use an external oil pump/tank or what are these hoses for??
I'll get pictures posted tonight, they'll describe my scenario a hundred times better. If this is In the wrong section I'm very sorry.
