Homemade lapping compound
Results 1 to 11 of 11
    creedmoor, nc
    74
    19
    15
    Question Homemade lapping compound
    I have a major shutdown coming up and am looking at having to do a ton of lapping and polishing when we do tear down and rebuilds. ??Would graded silicon carbide powder($4 to $12/lb) mixed with 50/50 mineral oil and light grease work as well as "Clover Compound"? Making our own would save a bunch. Any feedback appreciated.
    the old sailor
    Feb 2009
    Oz
    371
    16
    74
    You would need 2240lb less the weight of the oil to make a ton of lapping compound. Or 2000lb if you are in the USA.
    Apr 2007
    Dublin Texas
    2,540
    1353
    901
    Personally, I wouldn't mess with it. You are already saving x$ by reconditioning a sealing or bearing surface. But if its comming out of your pocket, you'd be surprised what you can do with toothpaste.
    have fun
    i_r_
    Nov 2008
    Fayetteville,AR
    237
    63
    10
    I lap on a daily basis with Clover. I used to by dry but would never do it again. I like the consistency of premix and really don't like the hassle of mixing. Dave
    Nov 2008
    Fayetteville,AR
    237
    63
    10
    I lap on a daily basis with Clover. I used to buy dry but would never do it again. I like the consistency of premix and really don't like the hassle of mixing. Dave
    Feb 2006
    SW PA
    6,024
    1266
    726
    Scott,
    What are you trying to lap. If you are trying to lap some half inch valves, use the Clover. If you have an 8 foot runner to repair, forget buying that stuff.
    Buy the Silicon Carbide in big carboys, lard oil in barrels,and kerosene. Mix, drip, and lap.
    George
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,380
    412
    1889
    I use the garnet grit used for sandblasting for very coarse lapping... Makes stones flat in no time when rubbed against glass..
    Nov 2005
    N E Florida
    1,995
    169
    YEARS ago my dad used to buy military surplus plug in radio crystals 10 for a dollar. He would remove the silicone crystal (4 screws) and grind it using Comet Cleanser on a piece of glass to change the frequency to use in C B radio base stations. At the time (1950's) IIRC C B crystals were $5. each!
    Don't know if the Comet would work for you but he sure did some fine grinding with it.
    Aug 2011
    Northern Germany
    1,449
    748
    788
    I recently lapped a 1 5/8" brass tube to reduce the out-of-round error it came with. Used as a cylinder in a replica of James Watts original experiment
    Since the only lapping compound we have sittin around is really coarse, i used Ajax, a brand of household cleaner. Seems to be a mixture of something like diatomaceous earth, soap and sand. I mixed it with some kerosene, let the sand settle, poured it off, let the fines settle, poured it off, mix the fines with oil and go !
    Worked fine. Obviously way too much trouble for anything bigger or any serious number of workpieces.
    You gotta be careful, sand with grains as big as 10-20 thou is not exactly what you want in a lapping compound....
    Jan 2008
    S-W Ontario
    450
    9
    20
    Job/work piece description would be helpful...
    If you are lapping a soft material you may wish to use a lapping compound that breaks down with use, so as not to continue lapping...
    Bon Ami cleanser springs to mind.
    Arminius
  11. #11
    Jan 2012
    San Bernardino Ca
    82
    26
    44
    My shop is connected to a place called Covington engineering. They sell all kinds of lapidary supplies from graded carbide to aluminum oxide. Depending on what is is you are lapping and how fine a finish you need you could even step up to a cerium or super cerium paste.
