Homemade toe jack
Results 1 to 18 of 18
    Aug 2006
    Kitchener, on canada
    795
    7
    172
    Default Homemade toe jack
    I need to move a 2 ton mill at a location with no forklift. Having done the routine of prybar and shimming to get the machine high enough to get on the pallet jack one too many times so I decided too invest the effort into building myself this toe jack to lift 2000 or 3000lbs.
    I did a google search of homemade toejacks before I started but I wasn't too keen on what I saw.
    Here is what I came up with.
    Google Docs
    Google Docs
    Google Docs
    Google Docs
    Google Docs
    I'm not a great welder so I will still be stacking shims beside the jack as a safety precaution.
    Jan 2007
    Norfolk, UK
    16,545
    12179
    11610
    Nice job, functional and will do what it says on the tin.
    As for the welding;- It's only MHO, but if that won't take 3000lbs you're a real crap welder of the first order
    Tip, plenty of grease on the slide, be surpised how they can jam up.
    Jan 2010
    Dresden On. Canada
    643
    1391
    124
    How are you going to move it once it's jacked ? ...Thanx Trevor
    May 2006
    northwest ARK
    2,927
    4172
    395
    Sbaer,
    There was a link on here a week or 2 ago about moving a machine . They had some really nice homemade toejacks on there, too. ( I'm not knocking your toejacks. They look good and I will probably make some myself someday)
    There are some other interesting points about moving machinery in that thread, also.
    Here is the link:
    How would you move this machine?
    Be careful,
    JAckal
    May 2002
    South Central PA
    12,447
    1515
    2625
    VERY nice - nicest design I've seen.
    (I'm gonna copy it...)
    Sep 2002
    Arizona
    3,175
    592
    325
    Thumbs up Nice Job!
    Nice! How long did it take you to make it?
    Cal
    Aug 2006
    795
    7
    172
    I wanted one that didn't but any moment load on the crappy hydraulic jack ram. It took an hour and a half to design it and about 4 hours to build it (the milling machine was cutting the gibs while I did some of the fab work). I used material I had on hand.
    Jan 2010
    Indianapolis, Indiana, USA
    5,474
    2426
    918
    Sweet. I like the effort you put into the slide.
    May 2002
    South Central PA
    12,447
    1515
    2625
    What happened to the photos? I can only open 004 and 005 now. I wanted to save them on my shop computer.
    Apr 2002
    Syracuse, NY USA
    9,569
    16
    533
    nstead of stacking shims, make a few hardwood wedges with low angles, just push them in as the machine is raised. a low angle of 15 degrees is ideal. When I did allot of rigging I had a whole bin of hardwood blocks and wedges of various sizes that I used constantly.
  11. #11
    Jul 2004
    Houston, TX USA
    27,102
    Here is a very quick and dirty one for a 25 ton ram that had no trouble picking up side of barn while setting up to replace sills.
    John Oder
  12. #12
    Apr 2009
    OH, USA
    46
    Mr. Oder,
    I'll agree with the quick and dirty and suitable for what it does. But SBAER's jack really does prevent moment load from being placed on the ram of the jack while still keeping the jack stable. Quickest way to ruin a hydraulic jack of that type is place any kind of load which moves the ram any direction other than parallel to the cylinder. SBAER you have a dynamite hydraulic jack.
    btw not trying to pick a fight, just saying the jack in above post really has some serious flaws.
  13. #13
    Nov 2006
    littlestown,pa
    1,763
    72
    20
    Mud;
    If the pics aren't back, I have them.
  14. #14
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,615
    2370
    5206
    Quote Originally Posted by mjmiller1824 View Post
    Yep, even those cheap "do it all" jack kits have a toe attachment...which work great...for awhile...and then due to the side forces on the ram the jack starts leaking like crazy and that's all she wrote, as the kit is so cheap you can't really justify the time to fix it.
    http://image.made-in-china.com/2f0j0...-Jack-002-.jpg
    Having said that, I suppose if Oder's creation dragged the back of the toe attachment body against jack body it would at least be better than using a toe attachment on a jack kit ram...where the toe is just "hanging out there" with all lateral support on the ram and seals, a recipe for leakage.
  15. #15
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    10,789
    3905
    3671
    Me too!
    (would like to see pics)
    thanks,
    smt
  16. #16
    Dec 2003
    Derry, NH USA
    375
    27
    21
    Default Help needed...
    I cannot open pictures....all I am seeing is odd looking characters on my screen.
    How to fix?
  17. #17
    Jan 2008
    Andalusia, Alabama
    797
    43
    8
    If you download the pictures they will open!
    Paul
  18. #18
    May 2002
    South Central PA
    12,447
    1515
    2625
    Got them, Thanks!
