Just had a shop press in new bearings for my 4x6 horizontal/vertical band saw. I had them replaced because it was leaking gear oil at the drive wheel side of the gear box. There is no spring type rubber seal. Looks like the sealed bearing (6202Z) is supposed to be the seal. The old timer that did this for me said he wouldn't even mess with gear lube and take a chance on leaks again. He suggested just packing the gear box with lithium grease. He's been a machinist for 40+ years and rebuilds Bridgeport mills. He said lithium grease is what he uses on all the machines he rebuilds. I picked up this bandsaw at a garage sale for $25 so I'm not too worried about screwing up the brass gear if grease is not the proper lube to use. I just don't want it to leak any more. This is just a home/hobby tool (I'm tired of using a portable band saw and getting crooked cuts). Will it be ok with the lithium grease?
