ASweetOldMan
- May 17, 2017
Hello,
I have had a 4x6 Horizontal bandsaw for a little while now so I could cut out piece of 6AL-4V titanium to use as handles for knives. The length of cut is around 5.5", and I've got the saw cutting pretty well at this point, but I'm not able to repeatedly cut alongside the line I want to cut. I've spent hundreds of hours now trying to build different jigs or systems to cut the line I want, but I have not been able to get a fully working solution. I'd like to have almost no material to sand off after I'm done sawing because it takes so long to sand stuff down, and I always end up burning myself.
I've tried drilling holes in wood just to hold the knife handle while I manually try to position it for the cut, and I'm just unable to be accurate with that system. I've tried many, many variations of jigs that I can bolt my handles to to account for the angle and such (so I can just leave the saw vise in the same position every time). Here are some pictures of the closest I have to a solution, but it still seems like it only works sometimes.
I added those tabs on the first picture so it wouldn't somehow change the alignment when I put each piece on, but it still doesn't work. The pictures after it (showing the Ti on the Jig) include those pieces now, but I don't have any more test pieces to put on.
As you can see in those pictures, the jig can function perfectly and allow a nice, accurate cut. However, it seems that something is not working right because right after I did that cut, I put another scale on (same exact hole locations and dimensions) and it left way too much material (almost 1mm).
Does anyone here happen to have advice for me regarding how to make repeatable and accurate cuts? Every time the saw messes up, it ruins quite a bit of work, and it's really starting to frustrate me.
Literally any solution to this would help immensely.
