Somewhere I read the angle on a metric variable speed belt is 22 degrees. If so, this makes no sense whatsoever based on my measurements of metric belts. I've got a pretty accurate high end dial type protractor and I'm measuring 76 degrees (or 14 if you change orientation, which I presume is where 22 comes from) on most. I did measure 72 on the most extreme angle one (or here again, 18 if looking at it another way)
So, where did the 22 degrees some from ??
Also, I measured one brand new inch type variable belt and the angle was only 83 degrees (or 7) !
Also interesting in this is that nobody that sells the things can answer the question of angle ! I've talked with four different companies, including AMetric and Motion....and they can't find the angle specs. AMetric is supposed to pull one out and actually measure the angle of the V, but a day later they have yet to do it.
