Degull
- Feb 3, 2014
- Toronto Canada
Hi everyone, I am a newbie. I have a Standard Modern 1120 lathe with quick change feed box. 27 TPI is not listed on the feed box chart, how would you cut 27 TPI?
..... a 30 tooth gear driving a 60 tooth, swap their position to double the ratio.
Gotchait would work if you had a 108 TPI position on the QC box!!!
Barber-Colman 10,000 Four-Gear Ratios... if ya got the big bucks, Pfauter has a version that must be ten million four-gear ratios, it's about six inches thick.damn hard to count from here but if those are dual 48 tooth gears then it would seem you could sneak a 64 tooth gear into the lower position and use the 36tpi setting IF your banjo will let you do it...looks like it swings off the upper 48 tooth sliding gear??
Set up a Cleveland some timeMy head hurts now so I might be all screwed up.
27 pitch? Unless you have a suitable change gear for the index you're pretty much up a creek. 27 pitch is used almost exclusively for small tapered pipe threads, some mike stands, and the straight brass pipe thread used in lighting fixtures. If the engagement is short and the thread is a set used like in a light fixture where mechanical strength is of little consequence you can use 28 threads per inch and bore or thread for clearance. It won;t fit right but it will do the job.
Pipe threads have to seal but since 1/8 27 threads engage but 3/16 to 1/4" and the material is ductile, you can cut the one thread 28 pitch and count on one time assembly, pipe dope and local deformation of the weaker material to make the seal.
These are hold-your-nose-and-get-it-done expedients no careful craftsman likes to perpetrate but if it gets the job done...Back in my South Bend days, I've resorted to them a few dozen times on grease fittings, gland flush connections, and the like with no call-backs. Needless to say my present lathe cuts 27 pitch.
My Smart & Brown 1024 is like this - the manual provides the simple formula, and you solve it for the available Integer gear tooth counts (about 26 in the standard set) and the available tpi in the 40 speed Norton gearbox (mostly integer apart from a few fractional tpi). Because you are not solving for Real numbers, you mostly need to use a suck it and see approach - try some munbers and see what errors you get - keep trying until you get a good combination, which may well use compound gearing. I wrote a little program to help me with a recent job which required internal screwcutting for a Thury -5 thread. No - I had never heard of this before and the pitch was 1.69 mm. I got a reasonable solution and cut the thread (Imperial lathe).
Notice
