oneMoreQuestion
- Jul 17, 2016
I picked up a #20 Whitney punch in sorry condition and was wondering if anyone had ever dismantled one before.
I found the original instructions and this is a 'pre' 1968 one without a removable ball race sleeve.
As found, the punch spindle has a bit of wobble to it when raised but not enough wobble that when punching, the punch ever touches the die. #1 Does anyone know if this wobble is normal?
I also want to inspect the ball bearings and clean the races. There are 3 set screw that hold the internal 'stop collar' on at the top of the punch body but after removing the screws, the collar doesn't budge. #2 Has anyone removed the collar and does it pull out, twist out or what?
As I don't have a sharp die or punch for this machine I can't really test it. With a rusted punch die set, its motion seems smooth but I want to inspect/clean to see if I can get it smoother before I invest in new punch/dies.
Thanks!
Thanks!
