wild_musk
- Apr 4, 2011
- albuquerque
I have been researching this but not completely sure I understand it well enough. I make folding knives, and I have a BP mill that would be really nice to be able to use for drilling holes, down to #54. Most of the holes need to be drilled, reamed, and bored for screw head clearance. I do not have a power draw bar. I do have a rotary table I use for cuuting the screw head clearnce to correct diameter, and a few other operations. I made jigs for centering the rotary table, which helped a lot, and more jigs to center work pieces on the RT. Drilling and reaming is done on drill presses, and I transfer work over to the mill to cut the clearance for screw heads. I think I can switch to ER collets and save time/increase accuracy by negating the need for a jig to center the work on the rotary table. If you're still with me, I appreciate it - is this what I really need? If so, what is the best way to adapt the ER collets? My mill has R8 currently. Do I need a new drawbar or what? The collets dont look like they come with anything else.
Oh, in case anyone wonders why I dont just sell my mill and use piloted counterbores, it's because most work is done in titanium and hardened steel. Counterbores are expensive and wear out quickly. Also, I customize screws/stand-offs/lock bars and require the ability to be able to use whatever dimensions I want. Finally, using a mill gives me a better sense of accomplishment and refinement of the end piece - as well as a bigger right arm from turning that drawbar so much. Thanks for any help.
