How do you drill chrome plated item?
Results 1 to 6 of 6
    Apr 2006
    Laytonsville, Maryland
    535
    11
    Default How do you drill chrome plated item?
    I am trying to drill small holes (11/32 inch) in chrome plated steel stampings. Using standard 118 degree point, HSS drills, I find that even with slow (225 RPM) spindle speeds that drill life is only about two holes. Hard to believe that chrome plating can be so destructive to the drill.
    Should I be using carbide drills or some other technique?
    Thanks in advance for any tips.
    Apr 2007
    Qc, Canada
    126
    7
    You can use a concret drill(the point is carbide) and sharpen it like a twist drill or use a carbide drill.
    Chrome is really hard.
    Jul 2004
    Asheville NC USA
    8,948
    3393
    2978
    I'd check the hardness of the material itself. I've drilled lots of holes thru hard chromed shafting, and it generally drills like the chrome isn't even there, unless the shaft happens to be one of those that's induction cased prior to plating. Those are kinda tough on drills, especially when you aren't expecting it
    Dec 2008
    Vt USA
    6,002
    530
    1836
    Hit the "to be drilled spot" with a mounted point powered by your die grinder till the substrate shows through. ;-P
    Mar 2009
    4,066
    79
    662
    CalG is right. You can also use a Dremel tool with a diamond point bit just to
    break the surface.
    Jan 2003
    Philadelphia, PA USA
    616
    Default Drilling through chrome plating
    First off, chrome plating is thin. You should use a solid carbide drill of 1/4 dia then follow through w/ carbide reamers until you finish the hole. 11/32 drill in sheet metal won't give you a decent hole
