Mud
- May 20, 2002
- South Central PA
The air lines in my shop are mostly 3/4" pipe. They were set up for a 5hp compressor and were plenty large. Then I upgraded to a 10hp and added a bunch more machines. Now I'm putting in a 15 hp and rebuilding the 10hp for a backup. The longest run inside the shop is about 100 ft. I could connect the main lines into a loop, so that any single drop would have air from both directions once it left the initial 15 or 20 feet of supply line. The blasting cabinet is the largest draw and it's very close to the compressor so I can run a large line easily to it. The next largest draw is a Cincinnati Cinturn that draws 23 cfm all by itself, it takes all the overdriven 5hp pump can make alone, and it sits right in the middle of the 100 ft long shop.
So what are the rules for pipe sizing? Does having too small of a line aggravate the creation of condensation? If I have to go larger I can most easily run a large pipe right down the middle and connect it in several locations to the existing 3/4 pipe. The shop is so crowded it would be a nightmare to pull out what's there and replumb it.
Any help? Suggestions? Rumors? Theories? Bar BS? I know how the lines should be run with the tees facing up and the lines sloped to deal with condensation, they are not like that now.
