Many years ago an old machinist told me "Ya never thrown anything away in a machine shop".
That's any Irish home. Whatcha DOO is kick it around until it gets LOST.
Which is why neatnik started the thread, I'd suspect.
One thing when you can't find stuff you know you have. Another when you are operating from the carpark because the stuff you can't find has filled the whole space and pushed you out.
Plastic buckets, sheet-steel office file cabinets? youse guys working thinwall aloominum tubing, only? Or what? Steels need "more".
Pipe cutoffs, PVC. No, not the little 3" ones. Go find some serious diameters. Like the buckets, only heavy-wall so as not to crack, viewed croswise.
Steel pails. Salvaged or other. They dent. Badly. BFD. Pound 'em out once every ten years. Or not. At least they don't crack. Plastics will crack. Or even shatter. Salvage a container, discover that great strides have been made in Bio-degradability of plastics. I kid you not. Stuff ain't what it once was, and that is regulatory not-just-cheap. But that too.
Got space UNDER a bench? Shit gets in there, it never comes out, right?
Unless.. every box is on its own furniture dolly. Easy out, easy back in again. Bench is your dust-cover.
Finding s**t. Stash those tiny LED flashlights all over the place. Refresh with another pak now and then. They grow legs. No space ever has enough light where you need it, when you need it. No light handy? You don't even try to look.
Tempted to store angles, nested, to then nest rod in the vee, to stash tubing one smaller size inside the other? Don't do that. If it doesn't HIDE what you have, it will be too much nuisance to unravel. You go and buy new instead, then add the drops from it to the problem, not the solution.
Rust. Folk who use it a lot know VPI paper and cousins are sold in pre-cut sizes, in rolls, and in large sheets folded. Get some. Doesn't take much to put under drawer liners and into hoards of drops. Pays dividends. Otherwise rustyugly offends, no time to mess with, you again buy new, add its drops in turn to the problem, not the solution.
Set a max level to the "hoard"'. If it has not been used, it will not be. Until ten years, or two days after it is gone. That will always be the case, whether you never had ANY, or still have a hundred tons. "Never" if it is not gone. Shed it.
Thin it periodically. Use, sell, scrap, even give-way. Space wasted, lost convenience, sustaining a mental inventory .. in total .. usually cost more than it is worth.
Oh."Good intentions".
No matter how many times you re-do all this at multi-year intervals? It will not be sustained for long. The container system implemented will be empty. Shit is all over Hell like it always was. Container system has become a trip-hazard.
Just Deal with that. Go on PM, ask the other guys how they fail their good intentions.
Remember one rule. THIS... they will lie about far more readily than whether they can, or cannot hit dead-nuts on spec threading Osmium to #00-90 on a clapped-out 1918 cone-head with HCS tooling. EVERYBODY always has clean undershorts, right?
2CW
