Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Like Tree7Likes
Thread: How to drill 3/4" Hole with 15" Drill Press (1/2" chuck)
    catalytic is offline Aluminum
    Feb 2010
    Cambridge/Boston, MA (Also Cleveland and LA from time to time)
    65
    Default How to drill 3/4" Hole with 15" Drill Press (1/2" chuck)
    I need to put a 3/4" hole in 1/2" mild steel plate. The trouble is, I won't be able to get in the shop for about 2 weeks, so I will have to do this with a Clausing 15" slow-speed drill press. The hole does NOT have to be precision by any means, but it must be drilled (torch and cover is not an option).
    I have lots of vises/tooling to keep the plate from spinning and the drill will do 250RPM. However, it only has a 1/2" chuck. What would you use to drill it? Drill a guide hole and then use a bi-metal hole saw (eugh...)? Is there a 3/4" jobber's bit with a reduced 1/2" shank? Some kind of rota-broach like thing? Whatever I get will probably just be used for this one-off job...
    rbent is online now Cast Iron
    Mar 2011
    Kansas
    335
    McMaster Carr number 2933A33 will get you what you want. They are known as reduced shank or silver and deming bits. If you drill a pilot hole that takes out most, but not all of the center web on the 3/4" drill it'll go easier too.
    JRIowa's Avatar
    JRIowa is offline Diamond
    May 2003
    Marshalltown, Iowa, USA
    5,698
    Forrest Addy is offline Diamond
    Dec 2000
    Bremerton WA USA
    8,707
    Yup. Silver and Deming drill. But - predrill about 10% larger than the chisle tip (web). 2/3 the drill thrust when drilling from the solid is required to force the chisel tip into the metal. Pre-drill and save a bunch of stress and strain. You don't have to step is out in small increments. Predrill then procede with the on size drill.
    mach2 is offline Aluminum
    May 2012
    Indiana
    221
    Does your drill press have a Morse taper spindle?
    Feb 2010
    65
    You guys are the best -- I had spent over an hour flipping through the Mcmaster catalog and I didn't see what you all found. Thanks for the help.
    My drill has the Jacobs 33 Taper. I plan to vise/clamp the work VERY well and go slow with lots of cutting oil -- hopefully won't see a proble
    lowCountryCamo's Avatar
    lowCountryCamo is offline Cast Iron
    Jan 2012
    Savannah, Georgia, USA
    313
    My local Ace hardware sells the reduced shanks if your in a hurry and can't wait for ups. I always wondered why they are called silver and deeming. Anybody know... Forrest?
    Philabuster likes this.
    Putch's Avatar
    Putch is offline Hot Rolled
    Nov 2011
    Butler, PA
    533
    agree with everyone on the reduced shank drill - no idea why they're called silver and deming drills either! I would use a 3/16" or so for the pilot hole at full speed and you should be able to drill the 3/4" at the same speed if not a little slower depending on how rigid your drill press is. One thing to remember with pilot holes is not to drill to close to your finish size or the 3/4" drill might just do what it pleases and go oversize on ya.
    Doozer's Avatar
    Doozer is offline Stainless
    Jul 2001
    Buffalo NY
    1,383
    Don't overlook annular cutters.
    A 3/4" hole saw can trepan through 1/2" plate easily.
    Even using a battery drill. Just use a sharp one and
    use oil with it.
    --Doozer
    Philabuster's Avatar
    Philabuster is online now Stainless
    Jul 2006
    Tempe, AZ
    1,648
  11. #11
    athack is offline Hot Rolled
    Nov 2009
    Michigan USA
    550
    Quote Originally Posted by lowCountryCamo View Post
    I beleive the original company that made reduced shank drill was Silver & Demming.
    Athack
  12. #12
    Bill D is online now Titanium
    Apr 2004
    Modesto, CA USA
    2,235
    the other good thing thing about SD drills is they are all 6 inches long. no need to crank the drillpress table up/down as you switch bits.
    Bil lD.
    see link for SD history
    VintageMachinery.org - Silver & Deming Manufacturing Co. - History
  13. #13
    Mike C. is offline Diamond
    Nov 2004
    Birmingham, AL
    9,817
    "I would use a 3/16" or so for the pilot hole at full speed and you should be able to drill the 3/4" at the same speed if not a little slower depending on how rigid your drill press is."
    Not unless you want to burn up the corners of your 3/4" drill, instantly. A 3/16" HSS drill in steel should be running around 1500rpm (about 70ft/min). A 3/4 drill running that fast is going to be running 300ft/min... about right for aluminum. The 3/4 drill should be run about 350rpm in steel. Running fast is going to be bad enough, but with a little flimsy underpowered 1/2" drill press, you are not going to have enough power to give it a proper feed rate, so the drill is going to be half rubbing, which will create even more heat than burying it in cold uncut metal.
  14. #14
    Garwood is offline Stainless
    Oct 2009
    Aurora, OR
    1,251
    Chuck 3/4 drill straight or taper drill in lathe, turn 1/2" shank.
  15. #15
    LKeithR is offline Cast Iron
    Langley, B.C.
    385
    Around here if you walk into a tool supply place and ask for a "Silver & Demming" drill you'd mostly get blank stares. Ask for a "Prentiss" drill and you'd get what you were looking for. Try to find a drill with 3 small flats ground on the shank. Use them in a good chuck and they work pretty well but I have lots of these with torn up shanks because the chuck just couldn't hold them. In my opinion they're only good for "emergency" use...
  16. #16
    Bruce Nelson is offline Hot Rolled
    Feb 2009
    Wisconsin
    993
    I believe you can buy Silver & Deming drill bits with 3 flats machined on the 1/2 inch shank so that the jaws of your drill chuck can clamp on the flats and not spin in the chuck when drilling the 3/4 inch diameter hole.
    Lord Byron
    John Welden likes this.
  17. #17
    Dec 2000
    Bremerton WA USA
    8,707
    OK i been tasked. The following text can be found verbatum in a dozen sites. I don't know where it originates or who to attribute it to. I assume it's credible.
    Silver & Deming History:
    Silver & Deming evolved from the 1854 founding by Albert R. Silver and John Deming of a company to make agricultural machines. They made a variety of machines primarily aimed at wheelwrights but eventually moved into drilling machines. They came up with the large-size twist drill bit with a turned-down shaft that someone could use in a chuck smaller than the bit's cutting diameter; however, they did not patent the idea and it was soon copied by other companies. The term Silver & Deming drills continues to be used as a generic term for this type of drill bit.
  18. #18
    Heavey Metal is offline Stainless
    May 2011
    1,610
    All drill bits for a post drill have 1/2'' shanks even the little ones.
    But they only have one flat on them.
  19. #19
    Doozer's Avatar
    Jul 2001
    Buffalo NY
    1,383
    An enormous amount abuse and damage has been inflicted upon the lowly
    1/2" capacity drill press by using S&D bits. I remember when I was younger
    watching my dad trying to monkey hump a 1" drill bit though some steel
    brackets for a bumper he was making. It was a good drill press (a Buffalo
    Forge) but it was still only a 1/2" capacity bench top model. Chatter to
    high hell and the chuck fell off a few times. At a young age watching this
    I knew something was not right with this method. But at that age, dad
    was always right (I guess). Now of course I know better. I own a large
    (4 Morse) Cleerman upright drill. I believe it could drill at least a 2" hole
    with ease. I guess I did learn something growing up. Maybe it is "Do as
    I say, not do as I do". I think all parents say that at some point.
    It is satisfying to hear a smooth running drill just slicing through steel.
    And the slight sizzle sound that coolant makes coming off a drill that
    is really ploughing through some thick steel.
    --Doozer
    vanguard cycle likes this.
  20. #20
    BobRenz is online now Hot Rolled
    Jun 2012
    Minnesota, USA
    742
    Another option is to use a 4-fluted core bit. They can be a little hard to track down, but many used machinery dealers will have some in their used tooling section. Do a web search for core bits, and you'll find them. I have a set that I've left in morse taper, and a smaller set that I've turned the shank down to 1/2". Since they are multi-flute, they cut very smoothly with no chatter, but they do need higher feed pressure and they like cutting oil. One web site I checked had a 3/4" for $ 82, but I usually pay only a few dollars at a used machinery dealer since most people don't know about them.
