How to enlarge a hole in a porcelain sink?? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Mar 2007
    On Elk Mountain, West Virginia, USA
    1,942
    712
    644
    +1 to find or make hardware that fits. Does anyone know a machinist?
  2. Likes thermite liked this post
  3. #22
    Oct 2006
    williamsburg va
    7,887
    839
    1713
    Don't damage the porcelain. Paint AIN'T as durable. Machine the brass instead if you don't want to see rust years from now.
  4. #23
    Aug 2008
    Sussex, England
    3,086
    12
    612
    This may be of interest How do I drill a hole into a cast iron bath? Drilling baths.
    As to coating in the hole I was told that its essential to use some sort of rust killer followed by a high build coating system with primer rather than a simple paint. Primer is really thin so I guess its more like an etch primer. When the coating system is fully hardened, takes a couple of days I believe, usual slatherings of silcone on assembly to really seal everything. Guy who told me decided it was too much trouble to have done so he got a new bath.
    Clive
  5. Likes Mark Leigh liked this post
  6. #24
    Jan 2004
    Halifax Nova Scotia
    1,745
    238
    Quote Originally Posted by jim rozen View Post
    Abrasive slurry with a clay dam. Thin walled brass tubing, have a pilot
    go through the hard stuff and then a smaller hole saw.
    Silicon carbide grit maybe
    I have done this job using the method recomended by Jim. As others have suggested plug the hole first with a wooden pug to serve as a center guide for the pilot drill. Then I hve used a very dull hole saw and valve grinding compound. You need just enough pressure to keep the grinding compound moving under the saw. lift the saw often and use a small brush to feed the compound into the kerf. It is slow but will do a very neat job of the hole with no chipping of the surface finish. The reason for the dull hole saw is that the teeth do not do the cutting but are there to move the grinding compound and the more surface area in contact the faster the grinding compound will cut
  7. #25
    Aug 2006
    Salt Lake City, UT
    296
    62
    80
    I bet somewhere out there on the internet there is a collection of guys, who would probably know someone who could make some nice 303 stainless adapters that could be brushed to give a nice finish in the tub.
    Maybe.
  8. #26
    Jul 2008
    Asheville, NC
    2,248
    936
    937
  9. #27
    Jul 2006
    Cumberland, Maine
    401
    21
    77
    As to the pilot question, Starrett make a special holesaw arbor they call their "oops" arbor. It allows you to mount two saws with the smaller one somewhat ahead of the larger - which makes the smaller saw act as a pilot.
    John
  10. Likes S_W_Bausch liked this post
  11. #28
    Jun 2009
    Near:Louisville, KY
    1,647
    120
    362
    Use a continuous diamond as mentioned above with a wood hole pilot and Absolutely drill from the top. It will break/chip if done from the bottom. Slow and Wet....
  12. #29
    Nov 2005
    Maryland
    8,508
    741
    1059
    Hi All,
    Thanks for all the replies.
    Here are a couple of photos of the sink in question:
    - Leigh
  13. #30
    May 2007
    New Zealand
    190
    there was a thread on making a type of hole saw - for making the round viewing glass for gauges - it was on this site some time back - may be if you still wish have a look at for it -
  14. #31
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    925
    Test a plasma cutter on an old fixture....
  15. #32
    Mar 2005
    Palmer, Alaska
    3,602
    735
    No sink expert, but looking at my 30 year old sink...
    If you cut thru the Porcelain with a cast iron base, you are creating a RAW edge..
    Said raw edge WILL, eventually get water under it, LIFTING porcelain from the cast iron as it rusts.....
    NOT pretty.
    Make a NEW fitting, to adapt to modern drain plumbing...
  16. #33
    Mar 2007
    England UK
    1,515
    611
    578
    Quote Originally Posted by The real Leigh View Post
    Hi All,
    - Leigh
    I've been drilling with diamonds for more than 20 years and I don't think I'd like to attempt that. Certainly not without the customer accepting all the risk.
  17. #34
    18,064
    7561
    5679
    Quote Originally Posted by magneticanomaly View Post
    Stroll down Lockhart Road (the porcelain and metals plumbing side, not the 'meat' plumbing side), or over on Mong Kok (same again w/r adjacent 'redlight' district) and I'd have the parts.
    Hard to name a fixture maker in Europe, Asia, or the US that does not have their wares on display here, and the range of fittings covers it all.
    Should be just as easy to order wot already fits online. Dirt-simple to adapt supply-side, just as easy on DWV.
    US 'Big Box' stores have a wide variety of 'appearance' choices, but not even a small fraction of the mechanical side choices in global use.
    Bill
  18. #35
    Mar 2012
    Geilenkirchen, Germany
    1,832
    1128
    907
    Don't do it! Find the correct parts. The UK is a great source for antique parts.
  19. #36
    Jun 2008
    Bellingham, WA
    3,630
    856
    1773
    Quote Originally Posted by gwilson View Post
    There is no doubt that the hole can be enlarged using one of the several slow and wet abrasive methods mentioned above. But George's observation is key here. The underlying cast iron will rust in between a few months to few years and will discolor the sink around the fitting. The porcelain in the sink currently continues right on down the existing hole. If you cut the hole and then stick in drain fixture I think it is almost certain to rust. As second significant drawback to cutting is the edges of the fixture will stand proud of the sink bottom. I would be willing to bet the original fixture did not stand proud of the bottom. Does that matter---yes, the customer wants a first class job here not a work around.
    Two reasons to either find a replacement (very likely could be done) or machine a new one.
    Denis
