Steve H. Graham
- Nov 6, 2007
- Miami
I have a Flynn boring head about 3" in diameter. It's a model 43. It came with a crazy arbor. The arbor is about 2" of 5/8" shank, internally threaded at the top end, with a taper resembling an R8 at the bottom. The tapered bit is maybe 7/8" long.
Problem: I can't get this stupid arbor out no matter what I do. I managed to put some decent torque on it by cutting a keyway in the tapered part and appying a hook spanner, but the boring head turned in the vise when I really cranked down on it.
People are suggesting I cut the tapered part down to 3/4" in diameter and use the boring head with a 3/4" R8 collet. My question: will a stub that short be sufficient to anchor the boring head in a collet?
I can make the stub an inch long by cutting into the arbor flange when I turn it down, but I can't do much better than that. I could conceivably build it up with MIG wire and make it longer.
The other alternative is to bore the arbor out of the boring head and remove the threads with pliers.
The boring head has a screw hole that opens onto the arbor threads. I didn't see anything in there that looked like Loctite. I filled the boring head with a combination of acetone and ATF and left it for a couple of days, and it didn't loosen up.
I'm afraid to screw around too much with the mill vise, because I don't want to bend anything on the boring head, and I don't want to use the dovetail or tool hole to apply leverage because I don't want to screw them up.
