I have a Hyd mec S20 Series ii and I am getting some inacurate cuts. I have checked the the guides and fluid and they are good. I'm using the same tooth pitch as I have always used, and I am cutting the same material. My feed rate is correct. The only thing I can think it could be is the blade tension. Does anyone know what blade tension I should be running on this mode saw?
