dazz
Stainless
- Aug 20, 2006
- New Zealand
Hi
I need to make specialised egg crate grille to shade sunlight. It needs to fit to a 10mm pitch which rules out standard grille (12.7mm pitch).
It needs to look something like this:
Which shows part of a 20mm x 10mm grille. The overall dimensions of the grille would be 320mm x 320mm.
In addition the surface needs to absorb incoming light.
Quantity is uncertain but it would be in tens of metres square, not millions.
I have rummaged around the Internet and I think I can buy 20mm and 10mm wide x 0.5mm thick aluminium on a coil.
If I run that between two rollers with many fine Vee-grooves. I can create a light absorbing surface ready for black painting/anodizing.
I could then have a pneumatic cylinder connected to a punch tool to cut the slots at the required pitch along the strip.
The only problem then is assembly of the grille. I think that could be a real pain.
As far as I know, there doesn't seem to be a machine weighing less than 1000kg that would do this job. I am thinking that a custom made machine may be the best option.
Is there a better way???
