edwin dirnbeck
Hot Rolled
- Oct 24, 2013
- st,louis mo
I have a LENNOX 125,000 btu overhead gas heater in my workshop.I only use it on the weekends,the rest of the time I turn it OFF.If it gets colder than about 30 F,the small SAFETY blower that evacuats the flue pipe is wimpy and takes too long to come up to speed and it times out.So I must stand there and restart it 3 or 4 times. Finnally after 3or 4 times I guess the oil in the bearings heats up enough and to motor comes up to speed .Afer the initial cold start the unit works fine.This unit is about 12 years old and it has allways done this .Years ago I put a 60 watt bulb under the motor and it will now work down to 20 F.I dont know why I put up with this this long ,but now I am going to fix it.About 5 years ago THE ELECTRONIC BOARD went out and I bought the new and redesigned board for about 180$.I am afraid to put a a stonger SAFETY BLOWER motor on it because ther might be some thing on the board that might burn up.ANY ADVISE WILL BE APPRECIATED.My old school lennox heater had a pilot light no boards and worked fine for 30 years until a storm knocked the buiding down.Thank you Edwin
