Ok some of you know from my other threads that I offer a service where I ream out PB barrels to accept a barrel insert of various sizes. Anyhow reaming thru that layer of anodize is killing my reamers. Right now I am using HSS reamers since they need to be really sharp problem is they dont stay that way long. I have tracked the use of my latest set of reamers and I get 15 uses before I start seeing issues. I am sure that I can get about 10 more good uses out of them but each time I have to baby the cut more and more (clear chips more often more lube generally more time per unit). So I am thinking about sharpening them in some way so that I can get more uses before scraping them. The main reason I am thinking about sharpening them is because the final reamer is kinda an odd ball size and is rather expensive to keep re-ordering (0.745 DIA). I am not too concerned about the tenths that I will loose by sharpening I can loose up to 0.002 before their is any real issue with the hole being too small. So the question is how would one go about doing this? I figure there is a couple options
1. do it manually the old school way (I would have to learn how)
2. Buy some kind of sharpener like a darex (do darex sharpeners do reamers?)
3. Find someone who can sharpen them for me and put them on a rotation
4. Keep with the status quo and keep buying them new.
So does anyone have some wisdom they would like to pass along? And thanks in advance.
