I have to pull on a crank pin with a tension spring. The pin is a 3/8 in. shoulder bolt. As a quick experiment, I just hooked the spring over the pin, and the action worked great. Now I have to make it last for thousands of cycles. So I will put a sleeve on the pin and weld a lug to the sleeve and hook the spring through the lug. My question is, should I use a steel bushing directly on the pin, or use a larger sleeve with a bronze bushing pressed in. At least the bronze could be renewed when it wears out. Problem is, in my experience Oilites don't last long when loaded sideways like that. And I bet the spring will still wear out where it hooks through the lug. I wish there were something like a thimble for the spring to hook on so the load isn't all at one point. Seems like a weakness of tension springs with hook ends.
