Scoobydude
- Dec 31, 2017
Ive tried searching in the internet for ideal tolerances for differant ordinary applications but no luck. I am no machinist, but my brother has access to a lathe and can make things if i give him a drawing so....
I am using that to my fullest . is there a page or something where it would list ideal tolerances for spacing between material to be....
Pressure fitted
Loose fitting
Snug but able to get out
Etc...
Right now my question is for my axle plate fixture. It uses 3\4 all thread(bought a common universal fixture that uses 3\4 holes) but my axle slot size is .88, so i need a spacer to center the slot on the all thread, but what size do i make my spacer? Certainly not .75 id by .88od, how many thou under/over.
And all the other questions in my head have no frame of reference such as this pair of triple trees i wanted to swap a stem on, but i had no frame of referance for how many thou oversized the new stem should be to be preasure fitted to fit in the old hole etc........
Need first question answered and hopefully a website for any other possible project.
Pressure fitted
Loose fitting
Etc...
