sjm512
- Jan 3, 2008
- Blue Springs, MO
I need to put new seals in two cylinders that about 8" in diameter. They have external threads on the cylinders and internal threads on the end caps. The end caps have nothing to grasp in order to turn. The only solution I can conjure up is to cobble up a really big strap wrench using an old 2" nylon cargo strap, but I knew that a lot of you would have run up agaisnt this before. How did you solve it?
Scotty Moore
Scotty Moore
