craigS
- Jun 27, 2011
- California USa
I need a suggestion for the O-Ring thickness to use on a hydraulic cylinder I am making for a project. Choices are: .070, .103 or .139 thick.
The cylinder has a 1.125" bore, 2.25" stroke is single acting with a miximum force of about 800 lbs (800 - 1200)PSI. Operation is via a hand pump so its slow and the number of operations would be less than 20 cycles per year.
I found pistons in Bailey's but they don't detail out the O-ring groove
Craig
Craig
