Hello everyone, I have a Herman Schwabe 20 ton clicker that's not working. I've looked for help online and called the manufacturer but keep hitting deadends.
The motor turns ON and the pump appears to be working. After pressing the push button switches to engage the press the solenoid valve engages but nothing else happens.
I'm not sure where to go from here. I'm suspecting a hydraulic problem since the electrical appears to be working. Could it be the seals? bad dump valve? Is there a way I could use a pressure gauge to narrow down the source of the problem?
Below are the system details:
Manufacturer: Herman Schwabe
Model: DT-Twin A
208Vac/3phase/3HP
Thanks for any adive you might have,
Joe
Model: DT-Twin A
208Vac/3phase/3HP
Joe
