My guess would be on Browning but it's just a guess. Others to check would be Martin Sprocket & Gear,
TB Woods (probably Lovejoy these days).
Thank you. I have noticed your past posts about the two Powermatic bandsaws in your family.
(BTW, if you do not already have them, there are manuals for the Model 87 saw and its Model
600 welder online.)
Can you see any markings on the drive/driven units of your 87? I had not seen the machine
in question when initially posting - I have seen it since but was under time pressure and did
not notice any markings.
Lovejoy has quite a useful catalog about variable speed drives
HERE. There is also an
Interchange Guide and some Installation videos on the same page.
I bought an early 60's Model 87 in the mid 90's, missing parts from the drive train. I called Powermatic,
the support guy said some parts were no longer available ... and then mailed me copies of the original
manufacturing drawings for those parts :-) A friend and I made replacements. The drawings made
no mention of 3rd party drive components - maybe the cone sheave halves were sourced, but most
if it was at least designed in-house, if not made in-house.
Thank you. Do you still have the Model 87 and the drawings?
In the Powermatic 87 manual, there are several exploded assembly diagrams of the machine.
These diagrams detail the components within the case of the High-Low Speed 'Transmission Box'
(p/n #8170). However, the diagrams merely show complete sub-assemblies for the Variable Speed
Pulley Assembly, Upper C'Shaft and Lower Variable Speed Pulley Assembly (p/n #8903 & #8905).
To me, this suggests 'we
built the H/L transmission and here is what we filled it with' but 'we
bought the variable speed pulleys - we do not service what is inside them'. This thought dovetails
with your post - the VSD pulley units were purchased and adapted to work on shafts and castings
developed in house.
