KC130Loadie
- Oct 24, 2014
- San Diego, Bay Park
Hey everyone, first post here on PM. I am a newbie to the machining world, and current student learning the trade...geared to the CNC side of things.
First mill I used was a Lagun FTV-1, and a couple of Bridgeports, then I got to use my buddies old Tree 2UVR with the "Z" collet quick change system and X-axis powerfeed.
So, after much reading, and reading, and re-reading, I found on Craigslist a Tree 2UVRC - Journeyman / Tradesman 200 that had some old NC electronics and servos / motors on it. It was part of a giant lot of gear to sell from a welding shop. I asked the guy if they would let it go separately, and they said sure. I asked how much, and they said $600. Yeah....$600.
I went down to the shop which is only 5 miles away to check it out. It has the body of a 2UVR-C all right, big box ways. No power feeds at all unfortunately (I guess that was redundant with the servos). The "kid" who works at the family (I assume) run shop and was handling liquidating their equipment said he had never seen it turned on in the 12 years he'd been there; it just sat in the back of the shop taking up room and were eager to get rid of it. I asked them to put power to it, and after some fiddling with the enclosure door lock / switch, she turned on. One of the other employees said that no one knew how to turn it on, and it was the first time it has been on as far as he knew. The NC control seems to be shot, no response to any button mashing, but the forward and reverse buttons fired up the motor and the stop worked as well.
Ahhhh, she purrs like a kitten. No grinding, clunking, nada...just smooth.
The table fed back and forth on the X-Axis very nicely without any issue.
I tested the spindle for any run-out...I couldn't find any. The quick change collet system worked fine, and they even had 8 collets. Checked backlash on the X-axis, there is maybe 1-2 Thou tops.
On the negative side, the motor brake doesn't work (I'm thinking the cork is just worn away).
The Y-Axis is almost impossible to move. It does move, but it is SUPER hard. I'm not sure if the servo motor was fighting me, or it was bound up from sitting for 18 years not being used.
The electronics (at least the NC part, there was no tape reader available) I am figuring are junk. I could hear different relays clicking when manipulating some of the major controls such as Auto/manual and Reset. The digital led's were flickering on and off on the X axis, and all of the mode lights were lit up.
There is no X or Y table locks due to the machine being NC I assume.
No power feeds at all.
So, I am going to use it in a manual fashion until I get some more coin together and will Linux CNC the beast. Not sure if I want to get a DRO just yet...although it would be really nice and a hell of a lot quicker than using dials. I am on a budget though.
What I am looking for is does anyone have any input or advice upgrading this mill to a newer CNC system? I want to go full 3-Axis, LinuxCNC / Mach3 etc. in time.
I have been looking at AjaxCNC w/Centroid, but it seems somewhat pricey.
If anyone has experience with this mill or converting / upgrading old Tree NC tech, I would be indebted to you.
P.S. Does anyone know if AdobeMachine is around? He has a very similar setup and I need to pick his brain.
