I need a "0" or "very little" clearance M6 tap - confused by 2B, 4H, D3 etc.
Results 1 to 9 of 9
    Sep 2007
    Washington
    4,486
    84
    1015
    Default I need a "0" or "very little" clearance M6 tap - confused by 2B, 4H, D3 etc.
    Hi guys,
    I know I should know this, but, I seem to have forgotten :-(.
    Spec says "M6X1.0 THRU ALL TIGHT FIT FOR M6x1 STUD". 303 1/2" thick. So I want an M6 tap with the smallest "class of fit," right? But, I see three different types of "class of fit" when I go searching in the MSC website -- "B" something, "D" something, and "H" something (I know, MSC sucks, but they are there and McMaster-Carr doesn't seem to have any class-of-fit differentiation at all) . Or are those actually not all referring to "class of fit?" Or am I barking up the wrong tree completely with "class of fit" and I want some other spec?
    Help me .
    Thanks, and regards.
    Mike
    Jul 2009
    Peoria, IL
    10,663
    36
    7930
    In the inch system, we use "H" numbers for tap size over nominal pitch diameter.
    In metric they use "D" numbers.
    Who knows why they can't be the same
    http://www.taylortool.com/wp-content...ses-of-fit.pdf
    Jan 2007
    Norfolk, UK
    16,535
    12166
    11603
    be warned Mike - I did some D3 class a while back - in alu, with taps and gauges supplied, and they were a swine to get right, ........IMO the amount over std pitch diameter was so small - everything had to be ''just right'' ..........my auto reverse tapper - which is neither a Tapmatic or Procunier was not good enough, .......I ended up hand tapping them in a tapping stand - like this but (hopefully) better Hand Tapping Machine | Grizzly Industrial
    Sep 2007
    Washington
    4,486
    84
    1015
    Thanks for the heads-up LS! It's only 2 holes in one part, so will hand-tap them.
    Regards.
    Mike
    Jul 2009
    Peoria, IL
    10,663
    36
    7930
    You might consider a form tap. My experience is that they do not go oversize like cut taps can.
    Sep 2007
    Northern Illinois
    3,094
    1370
    1603
    I'm going to stick my neck out here, because it's been a while since I looked, but I recall McMaster not having a selection of fit classes in inch taps, either. McMaster is nice, but they're not really a cutting tool supply house, and odd fit classes are just a little bit too esoteric for them. Call a local cutting tool supplier. I happen to like Walter R. Hammond Co. in Minneapolis, but I'm sure there is someone closer to you.
    Dennis
    Aug 2007
    Yuba City, CA
    314
    91
    120
    Quote Originally Posted by Finegrain View Post
    Hi guys,
    Help me .
    Mike
    The drawing needs to specify dimensional limits for this 'TIGHT FIT'
    and query the customer as to exactly how this 'TIGHT FIT' is to be gauged by them and you.
    Otherwise, everybody's just sucking wind.
  8. Likes janvanruth, Limy Sami, dstryr liked this post
  9. #8
    Dec 2008
    New York
    7,979
    2111
    loctite or vibra-tite will fix loose threads
  10. #9
    Jan 2014
    Temecula, Ca
    1,741
    770
    2334
    my favorite has always been the "Tight Slip fit"
    Just thread mill them. You can make them whatever size you like.
  11. Likes dave powelson, muckalee liked this post
