Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By Mebfab
Thread: Induction Heating and subsequent bending of 2024
    design123 is offline Plastic
    Aug 2012
    Pakistan
    5
    Default Induction Heating and subsequent bending of 2024
    Hi,
    We manufacture at our company, a 2024 strip like part (length=90 mm, W = 16 mm, Thickness = 2 mm) that is bent by 90 deg into an L - shape at particular position.
    So far we have been using the method of using a blue lamp to heat the part (after final machining) and then using a die and hammer to bend it to a 90 deg position. however the problem with this is a lot of rejections ( almost 50 %) of parts due to primarily cracking of the material at the corners of the bend.
    We believe this is due to improper heating of the part and thus are thinking of using induction heating process in some way.
    Need ideas and suggestions in this regard!
    Thanks.
    bjorn toulouse's Avatar
    bjorn toulouse is offline Stainless
    Dec 2007
    N.E. oHIo, USA
    1,321
    What is the radius of the 90 degree bend?
    Rex
    Aug 2012
    Pakistan
    5
    roughly 2-3mm from the outside. even lesser from the inside
    310 Guy's Avatar
    310 Guy is offline Aluminum
    Jun 2009
    Rosamond, CA
    173
    If you are bending a 2mm thick part, with a 2 mm outside radius, that means the inside radius is zero. Not going to happen with 2024. Open up the inside radius to 8mm (4xthickness) and you MIGHT get it to work. And BTW, if you are heating the part enough to bend it, you just annealed it at the bend. Annealed = no strength.
    Find another alloy or find another process. 2024 + bending = bad idea.
    LKeithR is offline Cast Iron
    Langley, B.C.
    386
    Quote Originally Posted by 310 Guy View Post
    Agree; been there done that, still remember the headaches...
    Mike C. is offline Diamond
    Nov 2004
    Birmingham, AL
    9,822
    Never bend aluminum hot. It gets soft, but gets brittle (hot short)... aviation sheetmetal 101.
    Mebfab is online now Diamond
    Jun 2003
    Mebane North Carolina USA
    4,843
    send the job to america
    Mike C. and 310 Guy like this.
