Industrial battery weight by dimensions or type ?
In this case, 32" x 29" x 21" tall. Type 24-85H-15, 24 cells (48 volts). Need to know how much this one weighs. Using search engine on the type I come up with different dimensions, but weight is about 2,500 lbs.
Can't know in general. Might have lots of lead, might have not much. But if they're good ones, a tad over a ton per.
Calculating the other 24-85-15 batteries on the web, I come up with 8lbs per cubic inch and therefore this one should weigh 2,436 lbs. Anyone disagree with that ?
Plus or minus a hundred or so depending on plate thickness.
Don, I think that works out to 1/8 lb per cubic inch rather than 8. Probably inverted the top and bottom numbers somewhere in your division.
weight (lbs) divided by volume (cu in) = lb/cu in
Yep... I divided 19,488 cu inches by 8 and promptly forgot the end result is 1/8 lb per cubic inch rather than 8....thanks for the correction.
My Deka (East Penn Mfg.) manual shows that size at a wt. of 2335# with a 95 list price of $6366, of course we then had to sell them for about 3750.00 as that's what the market would allow.If you own this battery it should be stamped on the side below the lifting holes.?
Correction to my last post as to weight. The wt. I gave was for the cells only- the wt. with the tray (box) is 2448 #. Looked down wrong column.
Thanks, neat to see my mathmatical calculations were within 12 lbs.
- You may not post replies
- You may not edit your posts
Forum Rules
