Inexpensive single point thread mill source?
Results 1 to 8 of 8
    Feb 2005
    Akron, OH
    1,619
    227
    1168
    Default Inexpensive single point thread mill source?
    I've got some parts I need to make a couple of - with oddball very fine threads: 1" 32. The parts are aluminum. I can get a tap and die from mcmaster but that'll cost a couple hundred bucks. I need like three of these parts.
    I'm thinking using the single-point style of thread mill, I just can't get over how expensive they are. Again, I'm making -32 threads in aluminum. Solid carbide isn't going to be necessary.
    Before I just start grinding on a standard 4-flute end mill, does anyone know of a place I get get, say, one high speed steel or inexpensive carbide single-point thread mill?
    Jun 2004
    San Francisco, CA
    3,050
    5
    63
    Could you take a 10-32 tap and grind all but one set of the teeth off? I think I've seen people mentioning doing that for a quick threadmill job.
    That would be pretty inexpensive to try. Of course, thats a pretty small diameter tap so you may not be feeding quickly or deeply.
    cheers,
    Michael
    Jan 2006
    Canberra australia
    42
    how about using a turning tool ! thats what I use in my mill it works fine . single point hss or even a hand ground one . easy
    Feb 2005
    Akron, OH
    1,619
    227
    1168
    Grinding a tap sounds like a great idea for what I need. Thanks!
    Feb 2002
    Peralta, NM USA
    5,428
    40
    327
    If you find you need carbide these guys are good: http://www.abtoolsinc.com/ThreadMills/Threadmills.htm
    Jan 2007
    Massachusetts
    5,105
    642
    1015
    Scientific Cutting Tools has a great line of fairly inexpensive thread mills in single tooth, staggered tooth, multiple flute straight, and multiple flute helical designs. For your aluminum application, I'd suggest their TM395-32C, in T15 HSS with TiCN coating.
    http://www.sct-usa.com/tm4.asp
    Oct 2007
    Grimsby, Ontario
    148
    If you have a small dia lathe threading bar, put it in a collet chuck and your good to go,, works very well for small qty parts,,
    Nov 2005
    Illinois
    1,731
    187
    982
    Hmm, I wonder if we are making the same part ( just kidding). I am doing a job in Alum that I am thread milling 8 holes. It have a 1.0-32 thread. I use a thread mill for a 8-32 thread. Works great. One thread mill lasts me about 5 months. The thread is only .25 deep and the L.O.C on the mill is .3 so I just make one pass and I am done. Using a single would be a pain. Too many circles.
