Installing spelter socket on wire rope
Results 1 to 9 of 9
    Sep 2005
    West Virginia
    3,892
    357
    Default Installing spelter socket on wire rope
    I want to install a spelter socket on a cable, and am wondering if I should do it myself or defer to professionals. It's going on a small die hoist crane, 3/8" cable, capacity supposedly 3000 lbs. (though the capacity placards were added later, and therefore don't necessarily have any meaning). The top of the hoist is about 8 feet off the ground, ie. things don't get lifted very high.
    I think zinc is the traditional fixing medium but I have heard that some sort of epoxy is more popular these days. Anyone have experience with this?
    Andy
    Jan 2003
    Stamford, CT
    1,603
    5
    I saw this done once years ago done with a type of Babbitt. I wouldn't trust doing by myself again with out experienced help. If its not done right it can fail unexpectedly. I would bet that just the weight of the lift never mind a load is enough to kill or seriously hurt someone. Can it be reworked to use rope clips or a crimped connection.
    Jun 2006
    glen cove ny
    115
    Default spelter socket
    A/F i would use a wedge soccket in the field. surf
    Apr 2006
    Fort Worth, TX
    1,303
    25
    26
    Here's a link to an informative PDF on wire rope terminations:
    http://www.unols.org/publications/wi...rminations.PDF
    Jan 2001
    San Diego
    396
    59
    9
    Default Epoxy sockets
    We used epoxy sockets when we replaced the steering cables on Medea. We got them from Coordinated Wire Rope in San Diego and since they do a lot of the heavy rigging work in the area, we figured their recommendation was good enough for us. Three years now with no problems.
    Jan 2008
    10
    I've had the best luck with having the local Wire Rope store terminate the cable for me. They have a 130ton press that swedges a nice bung in place just for this type thing and meets the cable rating (which is way over 3000lb for 3/8 cable). I'd expect it to cost about $20. Worth it for a vitical hoist.
    Mar 2006
    Seattle,Wa
    738
    10
    25
    We use Socketfast epoxy to put the D's on our tug wires, pull 10,000 ton barges just fine.
    Jan 2003
    Jacksonville, Florida, USA
    2,324
    10
    I used to test those zinc sockets at work on a Tinius Olsen testing machine and after watching the setup, and testing the sockets, no way would I risk my tuss on it. The professionals have enough trouble with them, much less an amature.
    David from jax
    Dec 2006
    the Netherlands
    199
    12
    We do this a lot for anchor wires and the like. The procedure is fairly simple:
    1. Reeve the wire through the socket.
    2. Unravel the end so that you only have strands of single wires. Put binding wire on the cable to make sure it doesn't unravel too far.
    3. Degrease the unraveled end thoroughly.
    4. Suspend the socket vertically and make sure the end of the socket is where the cable starts to unravel. Close the end off with a rag or tape.
    5. Pour in your resin. This used to be some kind of molten metal, but this has long since been replace by a 2-component resin such as "Wire-Lock" or "Socket-Fast"
    6. Wait till the resin is cured and snap off the protruding wires of the cable.
    A word of warning: our crews who do this have to follow a course and have a certificate. If the socket fails under load and there is damage to property or personal injury the insurance won't pay if the socket was installed by an unauthorized person.
