oompa
- Jul 19, 2011
- vermont, usa
Hello,
I own several different varieties of CNC machine tools. Winmax(hurco), trak,and three different versions of fanuc on the lathes and mills. We like that you can interrupt a program at any time on the hurco and then jump back into the cut.
I like running the fanuc machines, but my largest complaint is stopping the cycles to clean out chip build up un unexpectedly.
What is the best way to accomplish this? I have experimented with disassembling the door locks, but this just causes headaches with the control sensors. I believe I should be somehow programming an M1 and the associated spindle commands after every line of code, but that seems terribly inefficient.
