sconisbee
- Jul 21, 2006
- Cornwall UK
what is the best way to cut 2 symmetrical 6mm key ways on two sides of a tapered section of shaft. This would be on a vertical manual mill.
I know its a simple question but its not something i have come across before normally theres only 1 key on the tapered sections. If it helps, overall shaft length is 210mm and its an 8 degree taper on one end with a threaded section on the very end.
thanks
thanks
