moonlight machine
- Nov 19, 2007
- marysville ohio
This sad tale begins about 10 years ago when I had 2 employees. One of whom was an "expert" lathe hand. The expert was running some parts on my Leblond Servo Shift Regal. Picture this, 900 rpm he engaged the threading lead lever instead of the turning feed. Why was the threading lead screw engaged? who knows. Anyway the carriage / toolpost hit the 10" chuck with a crash I heard though I was outside at the time. Major carnage as you can imagine. Broken gears and a bent spindle. I bought the headstock contents of a machine that had been in a fire. This gave me all the gears I needed but the spindle was a L0 instead of an L1 as my lathe was equipped with. I needed it running so I removed the chuck from the set true mount and took a light cut off the the mount to true it up, replaced the chuck and that is how it is today. It is .007 out of true. I want to true it ID and OD so I can use my Rubberflex collet chuck on it. that gets to the question what grade of stone do I need to get a proper finish? I would rather not remove the spindle to remove the nut so I will have to reach inside it when I do the OD. Where can one buy mounted stones of a known type and grit? What type do I need?
