Hi all i have recently bought a warco gh1322 lathe, i have never used a lathe before so its all new to me i have converted it from three phase to single using a vfd i have the lathe up and running now with help from members on another forum.
My next step is making sure the lathe is running accurate, i have turned a piece of bar and this is what i got;
Measured with a caliper
110mm bar length
20.04mm start (chuck end)
20.33mm end
0.29mm over 110mm
Dial indicator
0 to 0.28/9mm
So they both are reading the same????
To fix this should i adjust the head with the two adjusters until it runs close to 0??
Im not sure if this helps but i have run the dial indicator over the face of the chuck and this indicates that its not running true, not sure if you can take a reading from this.
When i check the spindle collar itself the bit i clamp the chuck onto it runs practically at 0 on the front and the side when spinning by hand. but the face of the chuck runs of slightly could this cause the run off on the test bar or do i just need to adjust the head slightly.
Im self learning so any help would be great
110mm bar length
20.33mm end
0.29mm over 110mm
Dial indicator
0 to 0.28/9mm
