I have a 6 inch 3-jaw lathe chuck. It came with my South Bend lathe I just purchased.
It is marked: Union Mfg. Corp. New Britain Conn USA. 6 in. No. 1 2 3 - K
Last night I started taking it apart so I can clean it and de-rust it. It is overly dirty as it came from a shop that believed that oil and dust are the correct maintenance plan.
I started by using some ZEP degreaser on the outside of the chuck. It was so grimy and oily that I had to go this route.
Then I removed the jaws and wire brushed them for a few minutes by hand (no bench grinder in the house). Still could not read anything on the jaws.
Next, I dropped them in mineral spirits and let them soak for half an hour, then wire brushed them again and followed that with some medium brillo scouring pad rubbing.
I then soaked them in vinegar for an hour (definitely not enough, but I was running out of time) to remove some rust and followed this with more wire brushing and brillo pad scouring.
Lastly, I lightly oiled them with Ballistol (awesome gun lubricant from Germany) to keep flash rust away. It does, but while I was scouring jaw number 3, jaw number 1 was already flash rusting, so I had to redo it.
The jaws are marked 34 with nothing else (well, jaw number 1, 2, 3, of course).
Anyway, to make a long story, shorter, I noticed significant wear on the jaw grooves that engage the scroll and on the teeth that clamp on the work-piece. The chuck still works fine, though, so this post is not a disaster alert call.
Where can I find replacement jaws, and how can I figure out the correct model number to order?
Andrei
Andrei
