Hello folks, looking for some views on how youd order and go about things.
The part looks something like this. It also has a keyway running its full length.
Not wanting to make things easy ive aleady bored the tailstock so ive no fitting quill atm , I could probably turn up a plug that could serve temporary duty . I do have a steady, an MT3 hard centre and 3 an 4 jaw chucks. The through hole in the spindle is smaller than the part.
Matrial is EN19T.
Atm im thinking :-
Rough turn OD.
Mount it in the steady and drill the through hole.
Bore the pocket for the nut.
Make some sort of expanding spud to sit in the pocket that I can chuck on.
Flip the part in the steady and bore the MT3 taper.
Make spud for tailstock and drill a centre.
Fit centre to the part and mount between chuck n tailstock.
Indicate it in on the centre as best as and turn the OD.
Machine keyway in the shaper and hope it dont move.
Or something like that
In the same situation how would you do it?
Cheers.
Matrial is EN19T.
Atm im thinking :-
Rough turn OD.
Cheers.
