Live center in live tailstock?
Results 1 to 10 of 10
    Toronto,Canada
    78
    38
    26
    Post Live center in live tailstock?
    Does anybody have any thoughts on using a live center in a tailstock that has a bearing? Good? Bad? No big deal?
    Lathe came with a dead center in the tailstock.
    Thanks for your thoughts.
    Robert
    Jan 2007
    Norfolk, UK
    16,906
    12544
    12032
    ?????Sorry you've lost me there, more info or possibly a sketch / pic would help.
  3. Likes i_r_machinist liked this post
    Aug 2006
    greensboro,northcarolina
    2,129
    107
    397
    Glad I'm not the only one who doesn't follow that. A live center has bearings, but I've never seen or heard of a tailstock with with bearings.
    Sep 2005
    il.
    6,558
    29
    1175
    common in bigger and higher dollar/heavier duty machines
    as far as putting a live center in a live tailstock
    i seen it done many times to bypass a locked up live tail stock bearing
    not sure why else you would do it
    Jan 2009
    Manitoba, Canada
    484
    7
    So the tailstock quill rotates???
    Hmm....learn something new every day...
    Andrew
    Feb 2008
    Hawaii
    208
    5
    25
    Can the tailstock quill be locked to allow drilling?
    Toronto,Canada
    78
    38
    26
    Post
    Yes the machine in question is a 1992 mori seiki TL-40 that is sitting behind the Mazak 450m that i run daily. The mazak also has a "live" tailstock.
    I have only used dead centers in it.
    I have been at this company for a year and nobody has run the TL-40 (maintenence issues). Walking by i happened to notice the live center in the quill and thought it rather strange to have a live center in a tailstock with bearings.
    Probably the last fellow who worked here had some strange reason for using it
  9. #8
    Toronto,Canada
    78
    38
    26
    Post
    Quote Originally Posted by rbcmetalwork View Post
    No the quill cannot be locked to allow for drilling. But that would be sweet!
    I believe there are some Mazaks that have that option but I have yet to see one or hear from anyone who has used one. Apparently besides drilling you can hone as well!
  10. #9
    Aug 2002
    West Unity, Ohio
    23,112
    3417
    6393
    I have a big one like that - and the big bearings would git hot. This one has interchangeble heads on it. No MT at all.
    I removed the cartridge and made a plug with a taper in it and stuffed a smaller (#5 MT) center in it. Works better for smaller D / higher speed apps IMO.
    Think Snow Eh!
    Ox
  11. #10
    Feb 2004
    Sykesville maryland
    35
    8
    Default Lodge and Shipley lathes
    Lodge and Shipley long bed lathes used to have roller bearing morse
    sleeves built into the tail stock to take either a dead center, or drill.
    These spindle centers had real heavy duty bearings.
    There was a keyed locking collar that fit over the tail stock spindle
    with a slotted hole to lock the sleeve which had flats.
    Live centers introduce a lot of overhang for large heavy shafting
    leading to chatter and other problems.
    A live center failure will real quick lead to a catastrophic
    situation.
    If both sets of bearings are good the effects will be minimal.
    Two poor bearings rotating at random will induce various finish problems.
    Kap
