Page 1 of 3 123 LastLast
Results 1 to 20 of 46
    Ray Behner's Avatar
    Ray Behner is online now Stainless
    Mar 2009
    Brunswick Oh USA
    1,589
    Default Loading heavy iron in lathe
    I've got an overhead hoist on rails with an electric chain hoist attached. Tough to regulate the stopping of it, so I made this little cylinder with a needle valve to slowly let the piece down to the chuck and steady without a bang. Also nice for aligning the chuck to the spindle.
    Ray
    jdj
    jdj is online now Titanium
    Oct 2007
    detroit,mich.
    3,943
    If you worked for someone else, they would be one damn lucky employer!
    Jeff
    machine1medic's Avatar
    machine1medic is offline Titanium
    Jul 2006
    Clover Hill district, WI
    2,307
    Thumbs up
    That IS slick !!
    m1m
    Ray Behner's Avatar
    Mar 2009
    Brunswick Oh USA
    1,589
    Jeff,
    Darn nice thing to say! Thanks! You too M1M
    Ray
    aametalmaster's Avatar
    aametalmaster is offline Titanium
    Jan 2005
    Salem, Ohio
    3,850
    Cool
    Real nice work...Bob
    Bob Wright Metal Master Fab
    Salem, Ohio Birthplace of the Silver and Deming Drill, all others are copies.
    Ghost is offline Cast Iron
    Aug 2009
    Royersford PA USA
    282
    Brilliant idea ray. Gonna have to remember that one.
    the man machine is offline Aluminum
    Feb 2010
    Colorado, USA
    78
    Clever and resourceful. The way we like it. Yeah!
    ratbldr427 is online now Aluminum
    Mar 2006
    jacksonville,fl.
    214
    thats neat Ray.One of our presses has a Demag electric hoist single phase with a vfd drive.The pendant control allows you to move so slow it dosn't appear to move or rapid.I often thought how neat it would be to have it to load our lathes.I'll steal your idea so I can stop lusting after the Demag,which is probably a 3-4k$ hoist. Randy
    MwTech Inc is offline Stainless
    Feb 2005
    Fishersville VA
    1,596
    Check out the brake on the chuck, motorcycle?
    Ray Behner's Avatar
    Mar 2009
    Brunswick Oh USA
    1,589
    Quote Originally Posted by MwTech Inc View Post
    Actually it's from an ATV, but same difference. It's air powered to position the workpiece at different degrees for: cross drilling, spanner wrench holes and wrench flats on hyd. barstock. Oh yeah, I have a milling machine that mounts to the cross slide to do that work.
    Ray
  11. #11
    Krutch is offline Aluminum
    Feb 2010
    somewhere in Illinois
    163
    And a degree wheel!
  12. #12
    9100 is offline Titanium
    Nov 2004
    Webster Groves, MO
    2,549
    I have the same problem, more with changing chucks. They always stop too high or too low. Something similar would be just what I need. I'll get on it.
    Bill
  13. #13
    jdj
    Oct 2007
    detroit,mich.
    3,943
    Quote Originally Posted by Ray Behner View Post
    Ray
    I was wondering what that was. Another great idea!
    Jeff
  14. #14
    Ox's Avatar
    Ox
    Ox is online now Diamond
    Aug 2002
    West Unity, Ohio
    13,655
    Yeah - I'll give you another "attaboy".
    I like to see folks who will build what they need - rather than just doo what is commercially available and normal. I mean _ come - on, we are the people that MAKE the stuff in the first place! To not come up with our own fixes is jist crazy!
    Think Snow Eh!
    Ox
  15. #15
    Bill D is offline Stainless
    Apr 2004
    Modesto, CA USA
    1,882
    Nice design. If you put in a pressure gauge you could figure out the weight on the hook as well. I would use a double acting cylinder no need to make a resivor then. Did you make the degree wheel or buy one for car tuneups like the link below.
    Bill D.
    Amazon.com: Aluminum Timing DEGREE WHEEL Motion Pro Tools: Automotive
  16. #16
    Mar 2006
    jacksonville,fl.
    214
    Bill D. Because of piston rod displacement a double acting cylinder would probably not work so hot.I wonder if Ray used a retracting spring in the cylinder? Randy
  17. #17
    DieselPower is offline Cast Iron
    Mar 2009
    Centerville, TN USA
    337
    Quote Originally Posted by ratbldr427 View Post
    They do make double ended cyls... I have used them in a closed loop before. Problem is finding one that small, I guess you could just cut it down.
  18. #18
    Nov 2007
    marysville ohio
    2,685
    Quote Originally Posted by DieselPower View Post
    Why not just make one?
  19. #19
    220swift is offline Hot Rolled
    Oct 2004
    Montana
    901
    Ray
    Clever idea. What are you making a cannon ?
    Hal
  20. #20
    Ray Behner's Avatar
    Mar 2009
    Brunswick Oh USA
    1,589
    I'm making a 4.5'' hyd. piston rod. Running the chrome on the steady this time 'cause it gets turned down for a 3.5'' 12 thd. anyway. The hoist cyl. is just one way. Easy enough to retract by hand. I didn't want a spring inside to take up more room, thus keeping things close.
    Moonlight's right. Cylinders like this are easy to make.
    The degree wheel came from Summit Racing. I sandwiched it between the disc and chuck. The disc is an old metal slitting blade with the teeth cut off.
