Results 1 to 5 of 5
    engheads is offline Plastic
    Jun 2012
    Mid-Atlantic
    5
    Default logan 200 drive box
    Hi,
    New to forum.
    got a couple toys at good price (logan 200, atlas MF, tooling)
    However did not get the logan drive box.
    Not interested in restoration to original, therefore not buying a box that cost what i paid for lathe to start.
    what are my alternatives given a motor (1725 rpm), some angle iron, pulley etc.
    Also, looking at original drawing the pulley ratios are not that clear, anyone know what the rotation rate at the spindle should be for a given spindle pullley?
    Paul
    sophijo is offline Aluminum
    Oct 2010
    SE Michigan
    178
    Here's your answer man: Scott Logan at Logan Home Page
    Rex TX is offline Stainless
    Sep 2004
    Fort Worth, Texas
    1,421
    I presume you are talking about the countershaft assembly?
    You could use one fron another lathe if the pulleys match. Or you could skip it and install a 3-phase motor and VFD
    Jun 2012
    Mid-Atlantic
    5
    Rex,
    You presume correctly.
    I have the correct motor hanging around so figured it would cheaper to jury rig something.
    cozmo135 is offline Plastic
    Oct 2008
    genoa, IL usa
    49
    Quote Originally Posted by engheads View Post
    Rex,
    I have an old logan 820 that I have been using as a parts doner for other machines. I think the motor and countershaft assembly is still complete. If you're in the midwest we might be able to work out a swap of some sort. If interested send me a PM. Chuck
